GOOD Slicer software is critical for success with complicated prints. I recommend Simplify3D. Does the Cetus have a heated bed? It's crucial for using ABS. I use a Prusa i3 Mk2s
3D Printing: Step by Step?
Originally posted by Paul Alciatore View PostOK, I have decided that I will get a 3D printer. Haven't picked one yet. What I would like to ask is just what do I need and need to do in order to get started.
I have a first project in mind, a stand or holder for my TV remote. It will both keep the broken battery cover on and allow me to stand the remote in a vertical position on my desk. Here is a quick concept drawing.
What I want is to know where I go from this 2D CAD drawing. What do I need? And how do I do it? I would guess that a 3D CAD drawing would be the first step, but will any 3D CAD program do or do I need any specific ones. Cost is a prime consideration so no $10K programs, PLEASE. Free would be best.
And then what are the steps from there? Do I need any kind of program that translates the 3D drawing into something the printer will understand? Should I buy the printer first and work backwards?
You might be better with a "back of a cigarette packet" 3D sketch with dimensions,
- NickIf you benefit from the Dunning-Kruger Effect you may not even know it ;-)
I am playing around with Tinkercad and Fusion360. I think I am going to like Fusion360.
My sketch was not intended to be a polished drawing. The dimensions are about 2" wide, 1.25 deep, and 1" tall. I did leave off a line on the right hand view where the curved back meets the flat side, but I think that is obvious. Otherwise it is accurate: a "D" shaped brick, one inch tall with a "D" shaped, blind hole in the middle. Elf's suggested 3D model is not correct. He seems to have seen more lines than I drew. I will post a 3D version when I get one.Paul A.
Originally posted by Paul Alciatore View PostI am playing around with Tinkercad and Fusion360. I think I am going to like Fusion360.
I use autocad and then Cura to slice it and create the tool path. Best advice is just start playing. I read everything I could before buying and felt like there were holes in everything that I was reading. Once I started playing, it didn't take long before I was printing some very complex parts. I bought a prussa clone for right around $200 off eBay and have been very happy with it.
Sent from my iPad using Tapatalk
After a couple of initial sessions with Fusion, I had to concentrate on other things. I am hoping to get back to it soon. I guess I will find out how the free option works because I am sure the initial 30 days are long expired now.Paul A.
