Originally posted by Paul Alciatore
View Post
Cheap containers to help organize taps, dies, small amounts of hardware, etc
Originally posted by 3 Phase Lightbulb View PostIt's a large image, so a link is more appropriate:Milton
Originally posted by DICKEYBIRD View PostHey Adrian, I was looking around your shop & saw your G0490. I had to have to have Wayde & Brett from "Tanked" come over & build a full immersion tank for mine to prevent burning the edges of 4140 on pieces over 8 feet long. How did you get around that?I also have a shelix cutter-head on mine with carbide indexable inserts.. I can probably feed my bridgeport's table through my jointer
I saw someone use a 100W light bulb inside a metal cabinet to keep his tools from rusting due to humidity. I thought that was an awesome idea. I was thinking about doing the same, however it seems my basement is dry enough to not need this. Time will tell.12x16" Delta 3d printer (Built from scratch)
Logan 825 - work in progress
My Blog - http://engineerd3d.ddns.net/
Youtube Channel - https://www.youtube.com/channel/UCVY...view_as=public
Instagram - https://www.instagram.com/engineerd3d/?hl=en
Originally posted by JRouche View PostMilton
I find the clear plastic test tubes like the ones below are both durable and cheap.
They come in various sizes and included stoppers. Available from a number of sources including Ebay.
Originally posted by 3 Phase Lightbulb View PostWhy do you need to take so many drug tests in your shop?Home, down in the valley behind the Red Angus
I have access to a laser cutter and have been making really nice trays for my MT drills. I also just bought some inexpensive divider boxes for my geometric die head dies.
Struggling to add pics ...Last edited by sdalcher; 10-17-2017, 08:47 PM.
Originally posted by J Tiers View PostThere are many good ideas for storage. (even if it is a first world problem.)
One problem I see with many (like the old baby food jar deal) is the problem of expandability.... when you have more than fit, then what?
