I have owned an Industrial Hobbies mill for about 10 years. It is pretty big for a bench top model. It weighs over 800 lbs, has a big table, and a square column. I cringe when I ask it to mill somewhat hard steel but otherwise, for most of my projects, it is doing the job.
When I got it, the previous owner had put a 3-axis DRO on it which makes it a pleasure to use. Not long after I got the mill, I got an X-axis power feed from Harborfreight for a song at one of those parking lot sales. This was apparently a returned/opened item and I expected to find a problem when I would start to use it. But no, I set it up without problems, and have been using it without a hiccup since.
All of this to say, I've been pretty pleased with my mill from the beginning. It is not a Bridgeport or a Deckel or a Schaublin but it does the job. However, I can't stand the mechanism to raise the head of the mill. You need to turn a crank on the left side of the machine, and the ergonomics are all wrong. I hated it from the moment I started using it. I would rather change R-8 collets 3 times by hand than raising that head 1/2" up.
So, I cobbled together a motorized Z-axis as an exercise in "self medication", on the advice of my therapist! ;-)
I will present the problem and the solution in this thread in the days to come. I also have plenty of pictures to accompany the narration.
I hope you will like it.
