There's obviously more than one way to debur holes- use a countersink, drill bit, or custom-designed deburing tool. But what's a good way to debur the inside of a hole? I have need to drill several holes in pipe and to debur the inside so they don't present sharp edges to wires that will be pulled out through the holes from the inside.
The larger these holes the easier it will be to snag the wires and pull them through, but I do want to keep the hole size down to about 3/8 or so. There's probably a special tool that can be used for this, but I'm not aware of one. It seems to me also that since the inside of hole drilled in pipe will have a curve to it, there will be two points where the tool might tend to catch, and two points where the tool might not catch the burr at all.
What's a known good way to do this?
