A Tiny 3 cylinder Holt based engine
  • A Tiny 3 cylinder Holt based engine
    Gentlemen,
    Well the engine is finished and running. If you followed the build thread then you know the construction and initial running wasn't without incidents.
    Today I took it out on the bench and after a few adjustments it ran quite well but much faster than I had expected. The simple carb was much similar to the one used on the series of Tiny hit and miss engines so with the increased bore diameter of this engine I thought it would run slower.
    I took it back down to the shop and installed the original throttling carb then went back out for another try.
    While turning it over I started opening the needle valve until it caught and ran. While running I adjusted the ignition timing from the initial setting of about 15 degrees to almost 25 and it smoothed right out.
    Here is the video published on Youtube.
    gbritnell
    P.S. I'll have it at the Zanesville engine show this weekend.
    https://youtu.be/c_KtDdeMepk
    VERY nice! I wish I could garner the patience to undertake something like that.
      Well done! Wish I could work on pieces that size without bending or losing them.
      Dan
        That is just awesome and like the sound of that little bugger, I actually can't believe that tiny little carb *(and orifice) raps that little guy out that high lol
        nobody builds an engine quite like you G.britnell thanks allot for posting that - I have a huge project ahead of me for this winter and that video gives me hope...
          Well done.
          Really incredible how small it is at the end of the video when Mr Britnell puts his paw into the view.
            WOW!
            Nice job!
            Jon
              A masterpiece! Nice work.
              Makes my eyes hurt just thinking of all those small parts.
                George--I'd be proud to have an engine like that in my tractor. Beautiful work, as usual.---Brian
                Design engineer
                Barrie, Ontario, Canada
                  Thanks everyone for the gracious comments.
                  gbritnell
                    Originally posted by Norman Bain View Post
                    Well done.
                    It's probably a regular size motor, because he's clearly got huge hands.
                      It's so CUTE !!! I just love it.
                        Awesome work George! This must be George showing how to properly carry the HF mill
                          George, is that a Mustang LX in the background in your video?
                            George,
                            Thanks for taking the time to post the video. Your work is an inspiration for myself and a constant reminder that it is not the machine that is important, but the man. It is not craftsmachine, but craftsman.
                            www.thecogwheel.net
                              That's my 90 LX 5.0, 5 speed, just for fun car. It just went over 19,000 miles. Only touched rain once.
                              gbritnell
