Just when things were going so well. First time I tried to engage low and run, the head let out a clatter and I hit stop as fast as I could. After looking it over, I determined the Direct Drive Lever (high speed) doesn't raise the clutch far enough. I can put a large screw driver on the step pulley then raise it about 1/16"+ and move the pulley without hearing the ticking (when rotating by hand). It's the ticking that turns to clatter when the motor runs. (At least it appears so.)
Is there any adjustment to this other than making a shim to go under the direct drive lever collar on top? I think I could use the three nuts on top to hold the shim(s) in place. When in high gear, that collar is loose anyway.
I also noticed the lift pins (held in place by tiny set screws) seem a little loose. I'll go through that before making a shim.
On a better note, I almost have the DRO installed.
