why does the drill bit jump up when you first start to drill a hole on the lathe?
drill bit jump
Make sure the ejector is backed off and the chuck is fully seated in the MT. You're probably just seeing the chuck fully seat itself in the MT once you apply pressure to it. if it happens a lot you probably need to clean out the MT in your tailstock and make sure the tool tapers are also clean.
Because your not using a split point drill bit. If you look close at the very top of the bit the two tiny little flats at the point DON'T drill. Drill bits are all ground mostly the same so tinny ones are the same, puportimatly, as large ones. But look at a large bit for more clarity in what I describe. Split points don't have that little flat. That's the only differance.thats why they drill location more accuratly
Get a set of center drills or a couple in the sizes you use most.
I've seen some videos on YT where I don't know how some of these guys don't break bits. Or how they even do anything. The chuck and tailstock looks like they're flopping around. But I guess it's better than a bit brace...A little.
Originally posted by CCWKen View PostGet a set of center drills or a couple in the sizes you use most.
Pop rivet drills are cheap and short. Some of them I have cut in half to make two extra short starting drills for lathe work.Location: Helsinki, Finland, Europe
I use machine length 135° split point drills for pilot holes and make sure that I don't have a pip protruding on previously faced work, never had the problem of a drill bit jumping. This and good sharp center drills.
I could certainly see the issue arising when using a long drill in a loose tail-stock. This and what ahidley referred to in reference to the chisel edge portion of a drill bit, no self-centering function in that portion of a drill.Last edited by Willy; 10-20-2017, 02:53 PM.Home, down in the valley behind the Red Angus
Originally posted by dryfarmer View Postwhy does the drill bit jump up when you first start to drill a hole on the lathe?Chilliwack BC, Canada
No need, got it now.
OK, just for giggles try turning the drill bit in the chuck. See if it's just as bad or "pulls" in a different direction. It's not common but in cheap drill bits I've found some that are bent. Or if the shank was burred badly sometimes the jaw will sit on a burr and shift the drill around. Next up is to unseat, rotate and re-set the chuck arbor in the tail stock at a different angle. Again see if the "aim" is off the same or rotates around with the chuck. If all that is for nought then it's time to rig up the dial gauge and check for vertical alignment of the ram and see if it's sitting level and coaxial to the spindle.
With the ram extended about half way "lock" it and see if the dial gauge shows it lifting up some amount. You might simply have some wear in the ram and tail stock body so the fit is loose enough to allow the ram to sag a little. And finally with the ram fully extended and locked to center the end run the tail stock back and forth under the gauge to see if the ram is angled down towards the head stock side.
This can be "fixed" if you find that it's out in some manner or two but at least if you find an issue it'll explain what you're seeing for now. If it's simply that you're getting a little sag of the ram when it's not locked into the tail stock then it may well be that it's not hurting you any. The ram is simply lifting up within the "play" to center itself. If it's something critical and the ram lock does lift the ram up neatly perhaps just use a light locking force to center up the ram for the critical holes. Or if it's really bad and bothers you then it may be time to line bore the tail stock and make up a new slightly larger diameter ram? Or to bore out and fit an end bushing in the tail stock body to better center the worn ram's current diameter?
As part of my new "solid" lathe pedestals and alignment I performed all these and a few other checks. Ended up shimming between the tail stock upper and lower castings along the split line that is used to allow offsetting the tailstock for taper turning. It was a few thou low and now MOST of the time the drills enter the holes neatly centered. And when they don't the entry "kick" seems to be far less and far more random for direction. So that's just the cheap drill bits I'm using.Last edited by BCRider; 10-20-2017, 04:12 PM.Chilliwack BC, Canada
I always use a center drill like the picture posted earlier in this thread, both in the lathe and the mill, before using a drill. My most commonly used drills are all between 0.100" and 1/2". I have had too many bad experiences with "drill walk" to ever totally trust any kind of drill to start where I actually want it to. Another issue is that my lathe has a very wide saddle, so the drills have to be fairly long to reach the part held in the chuck to be drilled, or I have to have the tailstock extended over 2".Last edited by brian Rupnow; 10-20-2017, 08:22 PM.Brian Rupnow
Design engineer
Barrie, Ontario, Canada
