MichaelP, the handle is just as removable as a kurt vise handle. It pops in and it pops out.
The long tale of a vise tail...
Originally posted by MichaelP View PostYes, I understand it. It's just that you won't be able to rotate the handle full 360 degree without swinging it in the joint. It's not a problem for the final tightening, but very annoying for a long jaw travel.Jim H.
Thanks Jim, I tested the vise this morning to assess Michael's comment and that's exactly what I found out. You hold it out and the movements are short and rapid.
Long travels are not under pressure. It's only the last turn or so that needs to be torqued. At that point, all you want is leverage, and the handle, as it is, provide plenty of it.
Frankly, I'm perfectly happy with the result and its useability.Last edited by jariou; 10-25-2017, 12:10 AM.
