Ok elf: I'll bite ... what is the thingy in the image used for?
Indexing a large prime number, 127 for example.
Originally posted by Mcgyver View Postholy crap three of them? to avoid the mind numbing (its numb enough), I skimmed through.....I'm guessing even a still of 18:18 would capture the essence of it?
Not having a DRO shouldn't be end of the world, an excel program of the X/Y's would suffice...but of course be a lot more tedious
His DRO didn't just give a read out. It would calculate the coordinates for a bolt circle for you. Just enter start angle, number of holes and center diameter. I'm not surprised. The DRO on my lathe has quite a bit of math capability built in as well. Someday I'll have to read the manual.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
Originally posted by Paul Alciatore View PostAnd then you have to punch and drill them with great accuracy. That's the rub.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
That's an interesting indexer. How do you use it? It looks a lot like some tool post drills I have half made from ER collet chucks for my lathe. Well except for that massive indexing plate in the way. LOL.
Originally posted by Bob La Londe View Post
His DRO didn't just give a read out. It would calculate the coordinates for a bolt circle for you. Just enter start angle, number of holes and center diameterl.in Toronto Ontario - where are you?
Originally posted by elf View PostDoesn't anyone use a computer anymore??? Any arbitrary number of indexing holes can be calculated easily. Any 2d Cad program can do it in a few seconds.
J. Tiers, post no. 7 has the simplest answer. That is what I did to produce these dividing plates for my rotary table. I have just used them to produce a set of gears for a model traction engine and they worked perfectly. My interpretation of perfectly is to cut 31 teeth on a 30 tooth gear. The last one did not remove any metal.
P.S. How the hell do you post images? URL? what is that all about?
Originally posted by CCWKen View PostBS flag waving. It takes three months to years to learn a new language and draw with CAD software. I had a career in computers but I've gotten frustrated with every CAD sample I've tried. Those of us that think Paint.Net is challenging have no chance with CAD.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
Originally posted by Bob La Londe View PostThat's an interesting indexer. How do you use it? It looks a lot like some tool post drills I have half made from ER collet chucks for my lathe. Well except for that massive indexing plate in the way. LOL.
Here are several completed boxes:
