I like this method best as it will not have any welded or braised joints as possible points of failure. And the internal radii in the pocket will be 3/16". And you want a sliding fit and heat processes may cause problems if you want that to be a fairly close fit.
Another possibility that I do not believe was discussed above is the way one of my chuck keys was made. It has a square hole to fit a male, square head. It was milled from the side with a standard end mill, much like a short, wide, very deep keyway. This formed three flat sides of the square with two right angled corners between them. Then a plug was fashioned to fit in the side which the milling cutter cut away and that was braised in place to form the fourth side of the square hole. All four corners were completely square. In your case I would use a milling cutter with rounded corners (1/16" radius) and cut the slot. Then fashion a similar plug and braise it in place. This would be stronger than braising or welding two fillers in a cross slot.
Oh, and I am not any kind of expert at braising or welding, but in this case I would think braising would be better. A weld will only penetrate part of the distance of any joint and will therefore be somewhat weaker. Braising will allow the filler to penetrate the whole depth of the joint so, if properly done, it could (should?) be the stronger of the two.
Originally posted by MikeL46
View Post
