I currently have a drill press & vertical mill; both have MT3 sockets. When I require larger holes I use either hole saws or 3-flat (1/2 inch parallel shank)
Silver & Deming drills (both machines can be run at appropriate rpms) held in a Jacobs geared chuck.
While holes larger than 1 inch dia are very infrequent, I have located a source of MT shank drills at reasonable prices. Are there advantages to the MT shank drills that would make them preferable to those I already use? Most MT drills are much longer; my machines can accommodate this but I wonder if I might lose rigidity?
