I'm sure this has been asked before- heck I've asked it before
- but I'm having a hard time coming of with a definitive, solid answer.
I'm in need of a VFD for my 10HP Springfield lathe. The one "proper" VFD I've found that can definitely take single phase and give me 10HP worth of 3-phase, costs $1,200.
However, there's piles of Chinese VFDs on eBay that say they're good for 10HP/34 amp, for far less ($250-$300 plus shipping.) I'm given to understand, though, that generally speaking, a "10 HP" VFD is only rated for that 10HP on 3-phase. For single phase it'd technically only be rated for 5HP.
Or, if it were rated for 10HP on single, it'd be good for 20HP on 3-phase. The problem is, none of the eBay ads say anything about that. They all simply say "use 1 or 3 phase as you like".
So the $64,000 question: CAN the eBay/Huanyang VFDs actually run a 10HP motor on single-phase 220V input? (Example given, assuming the link works.)
Doc.
Doc.
