In the hot rod world we have such things as BILLET aluminum gas pedals.and TRUE RoLLER timing timing chains. Does anyone know how a TRUE ROLLER chain differs from a regular roller chain? Edwin Dirnbeck
True roller timing chain
I may be wrong but I believe the difference lies in that some chains have press fit "rollers" fitted to the pins while a true roller is free to float on it's pin. Think cheap bicycle chain vs. a motorcycle's drive chain.
Or maybe the rollers are hand carved from billet.Home, down in the valley behind the Red Angus
So looking at the link left by H380 I see by the little circled R that "true is a registered trademark of Cloyes Performance Products.
https://www.trademarkia.com/true-73275222.html
On Friday, August 22, 1980, a U.S. federal trademark registration was filed for TRUE by Cloyes Gear & Products, Inc., Fort Smith, AZ 72903. The USPTO has given the TRUE trademark serial number of 73275222. The current federal status of this trademark filing is REGISTERED AND RENEWED.Home, down in the valley behind the Red Angus
Originally posted by CCWKen View PostEh... Totally low-grade. It gotta be "reinforced space age polymer" or it's just high priced bicycle chain.
By the way, standard timing chains don't have any rollers. They just pivot at the links.
Search images of HyVo chain. That is timing chain and it is VERY WELL DESIGNED for the application. Many application really. Just keep it lubricated.
nylon overlay sprockets were to blame
By the way, standard timing chains don't have any rollers. They just pivot at the links.Last edited by Edwin Dirnbeck; 11-07-2017, 03:55 PM.
Roller chain has rollers that spin.
Bushing chain has rollers that do not spin.
Many times, #35 chain is called roller chain.
It is a misnomer, as the rollers do not spin.
Now, #40 chain has rollers that do spin.
This is real roller chain. The ones that call
#35 chain as roller chain, are ignorant or
outright lying.
Maybe it is more of a roundabout path than that.
There are swivel casters and rigid casters. Well
rigid casters actually have no caster offset, so
why the name? And if you want to get technical,
caster might be a misnomer as well. Don't casters
really have "trail" that makes the drag in the direction
that you want to go???
-DoozerDZER
Just a tad off topic; but the Cloyes site seems to be saying that they have a mechanism for changing what are fixed sprocket spacings to adjust for chain slack.
How do they do that given the tooth count cannot be altered?
To me it seems a change in the chain roller diameter together with a change in sprocket to match would be required.
http://www.cloyes.com/highperf.html
