I have a Friend (don't We all) Who needs a tommy bar. 3/8" diameter. What would be the best steel to use with no heat treating? Have access to all the common flavors of steel, 4140,1144,01,A2 etc. Medium bending stress. Would like it to last. Allen wrench type material would be nice but probably break the bank.
Strongest for bending strength?
Without any heat threating:
https://www.mcmaster.com/#standard-s...stock/=1a5lxbk
High-Strength 4140 Alloy Steel Rods (ETD-150)
With simple tempering at home oven: (temper at 500f for 1-2 hours)
Hardened Tight-Tolerance Multipurpose O1 Tool Steel Rods
edit: linking to mcmaster was fubarLast edited by MattiJ; 11-07-2017, 03:40 PM.Location: Helsinki, Finland, Europe
You know, I've always wondered just what combination makes a good pry bar.
I've got a 5 foot Pinch bar that has served me well for more than 40 years. I don't think I can ever bend it. Then there are those tire iron. The old "brown ones" are straight as the day they saw light. The newer flat and plated ones have been bent and straightened many times.
Is it a combination of hard skin and tough core? Or is it just tough through and through?
I wonder?
Originally posted by CCWKen View PostGo buy a 3/8" socket extension from HF. It'll probably out work any of the wet noodle suggestions so far.
the hardened O-1 from mcmaster is quite far from "wet noodle"Location: Helsinki, Finland, Europe
Originally posted by CalM View PostYou know, I've always wondered just what combination makes a good pry bar.
I wonder?
Like good hex keys that are ~60 HRC hardness and still not overly brittle.Location: Helsinki, Finland, Europe
Originally posted by CCWKen View PostGo buy a 3/8" socket extension from HF. It'll probably out work any of the wet noodle suggestions so far.Home, down in the valley behind the Red Angus
