So, whats best practice for milling a relatively precise angle on a long piece of stock? To be clear, im thinking cutting a 60 degree edge onto a piece of bar stock to make a dovetail straight edge, or other situation where youd have to hold the workpiece at an angle and cut along the X direction. If the piece was short enough i know you can clamp in in the vise and mill along the Y direction instead, but thats not really an option for a longer piece.
So, whats the standard for a task like this? Mount a vise to a sine plate? Special vise jaws? One of those funky angle vises? Im thinking a sine vise would be the best way to go in terms of both cost-effectiveness and work-ability. I did also consider an angle cutter of the proper angle, but ruled that out because, well, that only does a single angle
