Things have finally slowed down for the year in the shop and around the house. I believe have a chance to dedicate some time to building a project. As such I am looking for something along the line of a multi cylinder gas powered engine, or a machine tool. I don't want something that is so small it can sit on the shelf, but rather something that will either be able to make parts, or power some type of vehicle.
I'm looking for something in a "kit" form. By kit form I mean something that will include detailed prints, raw castings, or bar stock, gears or gear blanks, etc., etc.. In other words I don't want to spend more time sourcing parts and materials than I do fabricating, machining, and assembling. In the past I have taken on a few projects that ended up consuming more time at the drawing board (literally) and searching out components than it took to build.
Here's a link to a machine I made a few years ago:
http://gardentractortalk.com/forums/...2-4wd-cadtrac/
It has several functions and is literally used on a regular basis rather than sitting in a corner gathering dust and dirt. I'm looking for something a bit smaller, but again something that I can put to use or "play" with rather than store on a shelf or in a box.
My shop does have most of the the basic metal working tools including: vertical mill, horizontal mill, 3 lathes, 2 drill presses, surface grinder, hydraulic and arbor presses, vertical and horizontal band saws, power hacksaw, belt/disk sander, 2 tool grinders, shaper, etc., etc. I also have various pieces of wood working and sheet metal equipment.
I'm looking for something that will utilize at least the metal working tools, and am not averse to bringing the woodworking and sheet metal works into the mix. Any suggestions would be appreciated.
As a side note I did look at a couple model builders sites that did offer projects in either kit form or plans only. Most were geared for those that were looking to assemble parts rather than make their own. As such the "kits" ranged in price from $2,000.00 to $12.000.00. I'm looking for something a little less pricey.
