Internal Taper Measuring Question
  • #31
    Originally posted by Edwin Dirnbeck View Post
    I have been earning my living doing it this way for 60 years it is the fastest and easiest method that I have found
    Ok that's simple enough. Thanks.
    Would turning a steep stub taper, bluing it (or marker might be better) then putting it into the large end hole and twisting it to leave a mark so that the diam. at the mark could be measured with a caliper, be accurate enough for everyday jobs? I heard about this method but have not tried it.
    Southwestern Ontario. Canada
    • #32
      The taper would have to be dead sharp at the large end. If it's rounded or a burr around the hole it would move the apparent diameter down or up the stub you're measuring.
      • #33
        Here is how I measured many taper I mean hundreds The Caliper projection should be undercut and the front of the Caliper should be dead sharp
        • #34
          To damage my "expensive" Digimatic caliper or not to damage my "expensive" Digimatic caliper, that is the question. Worth thinking about.
          Alas poor yogurt I knew you well.
          • #35
            Are you trying to set the compound or measure the taper? I read the answers and got lost.
            • #36
              A better way to set the top slide for a taper AND how to measure the large end hole diam.
