Helping a friend fix up a house to sell. Central air needs to be replaced. Saw an ad for a used 2014 2 1/2 Ton Rheem R410A complete outdoor condenser and compressor unit and also an A Coil. Cheap deal, no return. Kept wondering why it was removed. A coil looked old. Checked the model number and sure enough the A coil was an old R22 unit. Since the pressure is so much higher in a R410A unit, and probably other reasons, the old a coils can't be used. Since the system was removed, someone must have proved it. So I started shopping for a Rheem A coil. They must be made of gold because they cost about three times as much as generic.
I had a Goodman unit installed at home and it has worked fine. Numerous HVAC installers use them because only one dealer in an area can get the big name brands and wholesalers don't care who they sell these generic units to. In that category of equipment I'm a firm believer in parts-is-parts. Same compressors, same fin tubes, Honeywell or White Rogers controls wrapped in sheet metal painted with the company's colors. I can get a Goodman 2 1/2 Ton R422A A coil for about $250 instead of Rheem's $900.
I'm sure my installer will connect whatever I have sitting there but with what is called a Georgia Guarantee (If It breaks I get to keep both pieces). Any HVAC experts here know how picky components are to mix?
