Cool hard turning video with sort of shear tool
  • Dan Dubeau
    It's all about where you direct your force. if you can direct it in a direction that is stronger, you can then feed faster.
    THe original video is cool, never seen anything like it. I bet that would be great for turning crankshaft journals, or other bearing surfaces deep between sidewalls. it allows a MUCH stouter tool to be used.
  • vpt
    Originally posted by Arcane View Post
    Everybody who watches that is probably thinking "What can I rig up so I do that on my lathe?"
    I've already tried that sort of thing.
  • MattiJ
    Originally posted by epicfail48 View Post
    I'll admit, I'm very confused as to why that seems to work so much better... I'm assuming that its something to do with the cutting force being directed along a stiffer axis meaning the tool can take a higher load, but I still feel like I'm missing something
    Yeah, stiffer tool. Basically zero overhang from the tool itself and no flex.
  • epicfail48
    Was actually thinking of some sort rotating toolholder one day after seeing the Sandvik Y-axis parting tool
    https://m.youtube.com/watch?v=BWmdsB_VUYg
  • dian
    why would that be faster, or the y-axis parting?
  • MattiJ
    Lathe Skiving is kind of related process:
    https://youtu.be/n5b7IimlLzg
    Now I have to admit that I never thought of that!
    Or power skiving that looks almost like cut knurling:
    https://youtu.be/lpzx_8pD2sM?t=38
    Bet that would make nice knurling every time without buggering the start!
  • MattiJ
    Originally posted by CCWKen View Post
    I don't have a CNC anything but those 1000*+ chips would start a fire at my place.
    Been there done that..
  • CCWKen
  • MattiJ
  • mattthemuppet
    dang
    looks like a shear tool that they rotate slightly to use a fresh part of the blade for every bit of the cut.
  • Arcane
  • MattiJ
    started a topic Cool hard turning video with sort of shear tool
    https://m.youtube.com/watch?v=2YA0CSA_sx8
    Never seen turning done like that.
