I've decided I need to make some electrical tool height setters for my machines with a fairly small foot print.* I've figure out my design so they will have a lot of over travel and good repeatability, but I am wondering about the anvil or touch surface.* The analog indicator type I am using now seem to have a steel surface, but they are softer than the tools and they will ding fairly easily if you make a mistake.* Because I do a lot of flood machining I was thinking stainless might be the ticket.* 304 for the body, and 303 or 416L for the anvil with an acetal insulator.* A harder machinable insulator might be better, but I am not sure what.
Definitely NOT something like HDPE since its compressible, and spring pressure over time might cause it to extrude and drift. I don't really have room for an off material setter to to be used all the time.* Adding soft buttons and macros to semi automate the tool height set is pretty easy for my controls.* It would improve my machine times, and reduce my necessity to deburr between tool changes more easily creating consistent parts.
