I made a post on the welding site and received a very helpful post from" magicniner" but I thought I would ask the same question here on the General site.
I am thinking about making a small wood burning stove for emergency use. I plan on using a 15 gallon stainless beer keg. I will need to cut off a slice down the side and weld a flat plate for cooking (the keg will be mounted horizontally on legs). I will need to put a collar of some sort at one end of the flat for a 3 or 4 inch stove pipe. I plan on a door with adjustable air intake in one end of the keg.
Now comes the tricky part, can I weld this up with either a A/C stick welder or Oxy/acetylene welder. I have had reasonably good luck with brazing stainless. With out a TIG or Mig welders, do I have any other choices. I have read a little on the internet about some welding rod for a ac stick welder and some on Oxy/acetylene welding. one of the online sites recommended 309 rod, is this reasonable ?
