Originally posted by Machine
View Post
welding stainless steel with ac stick weldler
Originally posted by JRouche View PostIts not bad. I just heat it in my garage electric oven and weld away. JR
Originally posted by MrWhoopee View PostNo, it was all taped together in an unprotected bundle.Andy
I guess I had better defend my reasoning to use a Stainless Steel Beer Keg to make a small "Emergency" use stove. 11 years ago I bought 5 stainless beer kegs at a yard sale for something like $5 each. I made two of them into charcoal fired BBQs, they are both still in use, no rust, no warpage. They both look as good today as they when made.
The metal in these kegs is thicker than you would think, I just measured mine and its .085 thick. Plus as you can see, there is a lot of contour which sturdies up things.
I think after I weld on a 3/16 or 1/4 plate top that the sides should not warp too much.
I'm not going to even use the thing unless things go to hell and we are without power for a extended time. I plan to build it and store it upstairs with the rest of my "dooms day" supplies. After I make it and try it and it warps, I'll cut off the top and find a chunk of Well casing at the metal recyclers._____________________________________________
Oregon Coast
Originally posted by Willy View PostI have to agree with Andy on this point. Controlling warpage on a carbon steel wood stove is difficult enough. Stainless steel has a far greater expansion ratio compared to carbon steel plus it's thermal conductivity is much less. These two qualities do not make it the best choice for use as a stove.
But hey give it a go if that's what's on the bench, go for it, maybe it will teach us all a lesson. But be forewarned so that there's no surprises.
That's a beauty Mel.
Hey you've proven we can all learn something new every day. It must have something to do with the stainless being anointed multiple times with beer...yeah that's it!Home, down in the valley behind the Red Angus
Originally posted by vpt View PostEnough humidity over time will many times cause the flux to flake off.
Lucky, or I would guess you live in a dry area?
The packs are foil wrapped and not all exposed like for the picture. It was had enough for me to get in there with a phone camera to take the pic.
The flux is secure and firmly attached. And I know what you are talking about. I have had some 7018 with the flux layer very degraded. The flux is firmly attached and the wire is straight.
I only warm it before welding to heat the core. Slightly. Its an old electric counter top oven. 230 degrees an hour prior. Works like a charm.
All other welding is inside with gas. I only use the stick for outside welds. That is why I have this old stick LOL. No outside jobs.
Umm the 316l stick was not cheap. It has a nice flux. I dont know its make up. The carton should say what it is?
With that? I would not. I would TIG process but would not make a burn barrel out of a thin keg. A SS three foot dia PIPE?? Yes..
Yes, stick weld SS, it does work. JR
