I want to put a Centroid allin1 DC servo control on my mill. It will be a very straightforward conversion as the mill is actually built to be CNC'd. It has power feeds on all axis, ballscrews on all axis. It should be as simple as it gets to convert!!!!!
Most of what I use the mill for is making slots, surfacing blocks of metal and drilling accurate holes. Now my question. Is it possible to clamp a workpiece, put my 3D taster in the spindle to locate the edges or 0,0 then mount a drill in the spindle and drill my two holes 50mm along my X axis?
Or do I have to do all in the conversational wizards? Is it possible to mount electronic handwheels in order to use the mill as one would a manual mill?
