I'd like to be able to cut metric threads on my SC4 without keeping the half-nuts engaged. Why? I'm trying to follow the technique of threading away from the headstock so that I don't (through my own ineptness) over-run the end of the thread. I've tried it with the half-nuts engaged but between winding past the start point and coming back to it (to take up backlash) and then starting the lathe with the tool already engaged, it's a bit painful. Videos of imperial threads where they just throw the half-nut lever as the thread dial comes round make it look so much easier....and I'm jealous
I'm aware that if the thread pitch divides evenly by the lead screw pitch that I can do this without a dial but since my lead screw pitch is 2mm, that only leaves me with 0.25, 0.5 and 2mm pitches that would work. The first two are definitely (at least for me) in tapping territory rather than thread cutting and the last is only useful for M14 and M16.
There are plenty of dials available for the C2 and C3 and I understand I'll need a different gear for different pitches. I found this one that includes 14, 15 and 16 tooth pinions, but it'll be designed for a 1.5mm pitch lead screw. Will it even fit a 2mm pitch lead screw?
If not, presumably the only way to go is to cut my own gear? If so, would it be a 2 Module Cutter No7 I'd need for this? I get that module of a gear = (pcd of gear)/(number of teeth) but don't know how to apply that to a lead screw - so the 2 is a wild guess.
Many thanks,
Gareth
Many thanks,
Gareth
