Metric thread dial obsession (going nowhere)
  • #16
    Here is a great thread that is on topic. Go to post number 6 to get an idea of what you need to make, and why.
    http://bbs.homeshopmachinist.net/thr...rk-with-metric
    I thought about that a while, and it occurred to me that there might be a back door way to do it without a thread chasing dial. It's based on the section that said "The half nuts can be engaged every 5 revolutions of the lead screw for proper registration" and "keep the halfnuts engaged to maintain the relationship between the chuck and leadscrew rotation."
    The idea is to put a dot on the chuck, and an indicator pointing to the dot. Then position the carriage so it's beyond the start of the work. Engage the half-nuts. Mark the ways, and add an indicator pointing to that mark. Mark the leadscrew and add a pointer to that mark.
    Theoretically, when all three of the marks align you have the nuts, chuck and lead screw back in their original orientation.
    Dan
    • #17
      Dan
      I believe the 'old timers' used to do essentially that by chalk marking the change gears.
      • #18
        I made the comment about left hand threads in post #6, as up to that point, no mention had been made of the problems and the OP may not have thought of it.
        • #19
          Originally posted by GadgetBuilder View Post
          Does your lathe have a spindle reverse or must you add that to thread going away from the headstock?
          Now that you've got Cleeve's book you might consider a dog clutch rather than a threading dial(s).
          Ooh, I want one of those! Regardless of whether it negates the need of a threading dial or not! I think I just developed a dog-clutch obsession too
          Yes, I've got the brushless version, Sieg's SC4 which will reverse at the push of a button.
          Dan: that's a good trick with the marker. A scratch pass saved me from myself despite me thinking that only an idiot could need it. It'd be useful for testing out re-engaging half nuts and seeing whether I get a repeat or a two-start thread without waste.
          I'll look into aligning by marks. It doesn't have quite the same feel as dropping the lever on a moving part and watching it run...but if it gets the job done
          • #20
            I think danlb's suggestion in post #15 is the best possible way to familiarise yourself with threading without tears. You can repeat the exercise any number of times and not cause any damage at all.
            • #21
              Just gash a gear like cutting a wheel with a tap, free spinning on a stub and the tap in the chuck, nylon or somthing would do, mount it with a mag base to the saddle when needed, a cannibalised clock gauge makes a good visual display, you can print a clock face and glue it in place of the original scale.
              Looks like a trav-a-dial.
              Electronic leadscrew?
              Just ideas
              Mark
