I bought a bunch of these LED volt meters. They all are accurate when put up against my digital VOM. However........ sometimes the last two digits will fluctuate.
What causes this??? One of them will be connected to a 6 volt battery which I'm using for test purposes. My digital VOM does not fluctuate but the small LED display does. Also the LED meter deducts what it uses to power itself. This is verified as I have my VOM connected to the battery also. When I connect the LED meter the battery voltage drops by about .30 volts and both my VOM and the LED meter read the same, so it's accurate but sometimes the last two digits fluctuate all over the place and my VOM tries to keep up. What's going on???
Does anyone understand what I'm talking about?????
JL..................
This is what the LED volt meters look like.
