Hope this works out.
  • Hope this works out.
    So I need some axles in a 40" disc to run fairly true. I only have a 10" lathe.
    The discs are only 1/2" thick so I wanted to build up a few to get some leverage in the axle and spread out the force in the 40" disc.
    So I cut out a 8" disc, and then a 12" disc with the 2" axle hole int he center.
    I wended the axle to the smaller 8" disc and trued it up int he lathe. Then used that disc to hopefully hold the axle true when welded to the bigger discs. Much like a bolt on axle on a truck.
    So what is it going to be when finished?
      Well if nothing else your mig welding looks pretty nice!
        Looks like it should work. I assume that was flux core wire? Mighty fine welding there.
        Dan
          That was with gas, I had the welder turned up decent so it was fairly hot, I think that is what the spatter is from.
          Will be a snow compactor for one of the local snowmobile clubs for doing trails.
            How cool is that ? The thing looks like it will work perfectly.
            Grammer question: Does a rhetorical question require a question mark ?
            John Titor, when are you.
              Looks like ten feet wide. What will pull it? Empty, I assume
                Yes the roller is 10', the frame over all is just shy of 11' wide.
                It will be pulled with a tractor. They used to use groomers around here but they are harder to get parts for and get worked on and a tractor works just as well. I am sure I will eventually get a pic of it behind the tractor. Also yes empty, the weight of everything adds up fast and no weight may have to be added. I explained if weight is needed we can weld on tractor weight hangers to the frame any time.
                  Good question!
                  Yes. See here: https://www.google.com/search?q=ques...nt=firefox-b-1
                  Also ...no space need precede the question mark.
                    A rhetorical question mark. Example:
                    Does a bear crap in the woods⸮
                      Great work. You really should do your welding first, then machine the axle true afterwards but obviously that would be very difficult to do in this situation. If you do end up having issues with the axle trueness, you could try welding the axle to a smaller 8" plate, then turn the 8" plate and true up the axle, then bolt the 8" plate with the axle to the center of the 40" plate. That way, you're still able to machine the axle after welding it, and just mechanically attaching it to the 40" plate after it is trued up.
                        Is it ok to yell movie in a crowded firehouse?
                          Only if there's no fire alarm...
                            Mounted the roller to the frame today and she spins with surprisingly little effort. However as expected culverts aren't balanced very well so it won't free spin for long haha. Another good one is a culvert isn't round either. Common for 1/2" runout, some places with 3/4" runout and a spot or two with close to a full inch variation. This will make for a pretty wide gap at the scraper bar.
                              VPT, your welding really is the bomb. I mean it looks like robotically, machine laden perfect beads. Can you share the details of what type of welder you used, settings method etc? I'd like to be able to weld 1/4th that good using my Hobart gas mig unit.
