Spline cutting work offered for once-off job
too much grease, it will spew out when it heats up. the package of grease they give you is slightly more then you need for one joint. if you cut the corner of the bag, then put it in the hole where the shaft goes, you can squeeze it all into the joint till it comes up around the balls. post up when part nine is up.san jose, ca. usa
