Help Wiring a 3 Phase Motor
  • Help Wiring a 3 Phase Motor
    I am in the process of replacing the motor on my Clausing Drill Press. I purchased a new old stock Leeson TEFC 3/4HP 1140 RPM on Ebay. I think I have it wired correctly but it is running extremely hot in a very short period of time.
    Not sure how to post image of motor plate but I have the leads wired as follows (low voltage):
    L1 - 1, 7 and 4
    L2 - 2,8, and 5
    L3 - 3, 9 and 6
    Am I missing something? I currently have it running off of my RPC and plan on installing a VFD but something seems amiss as it is running hotter than hell which makes me believe I wired it wrong.
    I would appreciate any help and/or guidance.
    Thank you,
    Joe
    your list is correct EXCEPT wires 4/5/6 those 3 tie together and not to anything else.
    L1 1/7
    L2 2/8
    L3 3/9
    4/5/6 tied together and insulated.
      If this is your motor click 'View connections'
      Says the same as our resident sparky says so don't run it until you have this fixed.
      http://www.leeson.com/leeson/searchp...0&productType=
      "...do you not think you have enough machines?"
        And if you find it's running backwards, just swap any two L1/L2/L3 phases (i.e: swap L1 and L2)
          L1 1/7
          L2 2/8
          L3 3/9
          Thanks so much, problem solved and I am grateful and appreciative for your help, truly.
          Joe
            Many thanks and much appreciation to everyone for the quick and very helpful advice.
              L1 1/7
              L2 2/8
              L3 3/9
              They don't call him "Sparky" for nuttin'....
                Amen...:-)
