Hello, I'm new to any of this. A friend asked if I could make some tapered pegs with my wood lathe and we got to talking about how metal ones would be better. I mentioned that I used a metal lathe in high school and did a quick search And a couple good sites popped up. I thought everything made is really cool and I've wanted a metal lathe since.
I have the opportunity to purchase a lathe. The seller has either a CT039 or a B2227L and can’t decide which one to go with. I’m leaning toward the b2227l because of the bigger bore (not much difference) and the all metal gears vs the ct039 which has one plastic gear. The ct039 has less use on it though, comes with more tooling (which I might be able to take if I buy the b2227l and it all fits), and a stand. The ct039 is also a lot lighter so it will make it a lot easier to transport into my basement if I decide to do any work during the winter.
Has anyone used either lathe? Which one would you recommend.
Thanks.
Thanks.
