90cm 40mm thick shaped like a camelback edge but obvious without the holes.
At the moment it does not pass the hinge test. Probably because it is a 3 foot edge made on a 2 foot surface plate.
It gives a variation of 0,02 mm. Less heat sensitive.
Giving you an idea when you think a piece of cast iron is unoptanable or to expensive or one of those reasons.
Angle grinder/ beld sander/ prussian blue and sandpaper various grits. Starting dry, ending wet. Up till now 6 hours in it.
Stone gets more polished now and difficult to read the blue. False readings because of porosity.
Already good enough for my plans, but will try to improve.
Do not drop.
Do not drop.
