I was given this shell mill. It has 2 damaged threaded holes that was drilled out off center. I had the idea of drilling the threaded holes oversized and tapping them out to go the larger screw and drilling and tapping the screw to the size of the original torx screws
The other method is to weld up the original holes up and drill and tap them to the torx screw size.
Any suggestions and comments
Sent from my SM-T550 using Tapatalk
