A friend of my has a 20 ton hydralic press which he uses mostly for rebuiling gearbox. He asked me if I can machine him a die which will punch a 1" hole in 1/8" mild steel plate. First of all, how do I know if 20 ton is sufficient for the task and where can I find information about the size of the die and the steel type which should be used. I'm assuming that the die will need to be heat treated. I'm not sure if I'd undertake this project but it sound challenging and I like that.
Albert
[This message has been edited by Rotate (edited 05-22-2002).]
Albert
