I'm with you on the bench space Jerry. I just about choked at the post above suggesting you ditch the bench in favor of a few small spots dotted around the area.
Folks with small shops and larger machines... How much space between machines?
Originally posted by J Tiers View PostI have a Rivett 608 on about the biggest stand they made, a 10" Logan, two largish bench mills, and a 7' tall DP, plus bench and of course the usual toolboxes. etc. I do need to fit in a Glendo and preferably the small arbor press. And I want LOTS of bench space..... I want "clock" space, not "watch" space. Maybe not "tower clock" space, but......
There were questions about wall and under bench storage
Wall 1, which will be partly covered by rollaround
Wall 2, which will be blown away but would have been over the Rivett
Under the bench (with some occupants being used elsewhere)
Under the lathe (cutters, turret, small stock, press, etc)
Originally posted by 3 Phase Lightbulb View PostNot familiar with any of those machines or Clickspring's machines. You should post some pictures of them because they look like kitchen appliances in your drawingsLast edited by J Tiers; 01-10-2018, 10:06 PM.CNC machines only go through the motions
Been messing with layout ideas, and finally came up with what may be an improvement on the prior versions. Generally uses space at least twice. A little more crowded by the bench....and in front of the tool wall. Nothing is perfect.
