Press Fits in Nylon
  • #16
    I said it earlier but will be more direct: Nylon absorbs a lot of moisture and will swell significantly. Use some other material.
    If you don't believe me then try it and see.
    • #17
      To prevent the nylon from walking off the steel sleeve, machine a groove in the middle of the steel sleeve to fit a split ring.
      Machine a matching groove on the inside of the nylon. The split ring will compress on fitting the nylon over the steel sleeve and snap into the groove in the nylon, making it darn to d**n hard to ever get the nylon off.
      • #18
        Isn't this what I said????
        JL..............
