Tin Foil Source
  • Tin Foil Source
    Here's a question I ask from time to time when the thought occurs, and since I have yet to ask it here, I thought I'd give it a shot:
    Anybody out there know where I can get some REAL tin foil?
    FF
    http://www.frets.com
    Frank Ford
    HomeShopTech
    Yes, try a Dental suppliers they have usually small rolls in a container the size of a small medicine tub.
    Approx. say ten feet by four inches when unrolled if in trouble email me and I will make enquiries here for you. good luck in the meantime. Alistair
      McMaster-Carr www.mcmaster.com might have it.
        Hearing "voices" and want to make a hat ?
          Alistair - I didn't realize that dentists use the stuff. I see from a quick dental Google that it's commonly available from dental supply houses - THANKS!
          DT - No, so far the voices appear to have bodies nearby that are producing them, so I think I'm OK, at least for now. In case you're wondering, tin foil is the material of choice for conforming to delicate surfaces for molding with plaster of paris and/or other compounds. It turns out that even the thinnest aluminum foil is a bit stiff when it comes to really laying down smoothly on a super delicate surface.
          Here's what I'm up to:
          http://www.frets.com/FRETSPages/Luth...LTop/a4l1.html
          FF
          Frank Ford
          HomeShopTech
            Yes it's used mainly to block out undercut areas whan making dentures and relief chambers in upper dentures for people who have a rather bulbous area in the palate known as a Torus Palatinus. These are discarded before the appliance ever reaches the patient so it is never put into the mouth kind regards glad I could help. Alistair
              Wow.
                <font face="Verdana, Arial" size="2">Originally posted by Alistair Hosie:
                a rather bulbous area in the palate known as a Torus Palatinus. These are discarded before the appliance ever reaches the patient so it is never put into the mouth kind regards glad I could help. Alistair</font>
                If that's anything like a duck billed palatinus,I wouldn't want one in my mouth either.
                Allan
                  Alan your from south of the Border you already have a duckbill palatinus awfooooly posh
