Sourcing and making Poly-V belt/ ribbed belt pulleys
  • Sourcing and making Poly-V belt/ ribbed belt pulleys
    In another thread I mentioned making these poly-V pulleys.
    Just a heads up in case anyone else wants to buy cheap pulleys:
    Automotive alternator pulley is abouts 45 to 63mm and you can get new ones for less than 10 euros a piece when you find right shop. 20euros a piece gives you already plenty of selection. 17mm bore seems to be most common.
    Power steering pump pulley is something like 100 to 160mm diameter, I haven't found any new source for these but junk yard in eastern Europe sent me one for 10 euros including shipping
    (Audi A4 pulley, about 150mm pitch diameter)
    Automotive sized PK belts are easy to find in sizes between 700 and 3000mm.
    "Industrial" Taper-lock pulleys were crazy expensive with several weeks lead time. Other belts than automotive sizes are not too easy to find either. (still easier than pulleys)
    I've got two 250mm x 85mm disks of aluminium waiting to be turned into poly-V step pulleys for my milling machine. I have got the belt, but am quite worried about how small it is. J section with four grooves for 2hp. It's tiny!
      Figure 50% efficiency for a car alternator, so its not that bad.
        The hp transmittal capability of the J section belt is quite high, but it depends on the speed and the pulley wrap. Graphs are available... https://www.myodesie.com/images/wiki...Chart_edit.png
        I have no issues getting reasonably priced J-section belts in the USA and pulleys are dead easy to make. I get a stock cast iron taper lock "B" belt pulley, turn off the sheave and insert a 6 (or more) groove j belt poly-v profile on the remainder.
        Like this (follow link).
        http://i238.photobucket.com/albums/f...9049Custom.jpg
        http://i238.photobucket.com/albums/f...9051Custom.jpg
          cars are typically K section.
            Making the pulley is not difficult. I think I made one in cast iron way back when I only had a lowly "109" lathe. That one is still working.
            Just takes grinding a cutter to fit, and doing some measuring while making the part. I was reducing the diameter a bit to get a different speed ratio, so I had grooves to fit the cutter to.
              Hi mark with apologies Matti being a Poly Vee addict had to jump in
              Six ribs will fit OK as 85 / 4=21.25
              6 ribs j Poly Vee = 14.04 + 2.34 = width over grooves 16.38 will fit OK. Make the outer diameter of the pulley 4 to 6 mm greater than the crests of the Vees.
              Alignment is critical shafts must be parallel and groove lined up and tensioned.
                Anpther pretty good design guide including basic pulley dimensions:
                http://www.optibelt-usa.com/fileadmi...BBED_BELTS.pdf
                I did one pulley from mystery steel and can’t say it was dead easy if not too difficult either. With K profile you need to cut about 8mm wide chip or take gazillion smaller chips if you get too much chatter.
                  For taperlock use, you can buy a ready made female cone to adapt/weld to a normal pulley:
                  http://www.fptgroup.com/dss/docs/689...ft_Fixings.pdf
                  Helder Ferreira
                  Setubal, Portugal
                    If the large pulley is more than about five times the diameter of the small pulley, then you don't really need to groove the larger pulley, just the small. The torque transmission will be limited by the small pulley.
                    Paul Compton
                    www.morini-mania.co.uk
                      This is taken to extreme on washing machines, belt pulley ratio is something between 15:1 ... 30:1
                        You can also step-rough it then profile in a couple of final passes.
                          i wouldn't want that for lathe less than 5-10 hp
                          edit: this post was reply to "someone" posting 6 tooth profile tool. Seems like he did ninja edit later on and now my reply looks like out of place
                          Should always quote the poster you are answering ..
                          http://www.machinery.co.uk/article-i...0215_popup.jpg
                            Way less with J-section
                              Is this the pulley type that John Stevenson said he made hundreds of using a 11TPI thread chaser? I bought a chaser I found at a tool shop just in case I ever had to make such a pulley.
                              Monarch 10EE 1942
