Brian does Ridders flame eater
  • Originally posted by J Tiers View Post
    That is a work of art
    If it does'nt fit, hit it.
    https://ddmetalproducts.co.uk
    http://www.davekearley.co.uk
    • Originally posted by Davek0974 View Post
      He mentioned warming the engine up before starting it. In fact, there are countless references to warming up these engines before they will start. Ridders instructions make reference too. Brian made no mention of warming his up before starting attempts. Ridders instructions give detailed measurement methods to tell if the engine is "loose" enough also.
      Here is a video about warm up with some good explanations in the comments section. https://www.youtube.com/watch?v=zgbFoUE4VyY
      • Interesting,
        I would like one of these....
        https://youtu.be/Mw1W7f_WtaM
        • There are some fantastic flame eaters on Youtube. I did preheat my cylinder. I tried it with some oil. I tried it without any oil. I tried with every conceivable flame height and 95% alcohol. I tried it with every flame position. I've tried clockwise rotation. I tried counterclockwise rotation. I'm now waiting for either a full moon, or to get my machinable graphite.
          Design engineer
          Barrie, Ontario, Canada
          • I must have got up on the right side of the bed this morning, because today I have a runner. The only thing different from my previous attempts to make this engine run is that I squirted some WD40 into the cylinder before I tried to run it. I am using methyl hydrate (gasline anti-freeze) for fuel. Nothing has been changed mechanically since I finished the engine earlier this week. I have a stick of machinable graphite on order to make a new valve and piston from, which will replace the current cast iron piston and valve. Oh, I am so happy. There is nothing worse than building an engine and knowing that you've done everything right, and then the engine won't run!!---Brian
            https://www.youtube.com/watch?v=tI77...ature=youtu.be
            Design engineer
            • Fantastic news Brian, we just had a full moon a few days ago so perhaps being on the back side of it helps align the polar momentum.
              Congratulations!!!
              Amazing how particular these little fellows are as to what makes them run or not. Probably something to do with the efficiency and nano-hp output .
              • Good work!
                Jon
                • Nice work Brian! Runs very smooth and pleasing.
                  Were you able to speed it up at all?
                  • Super!
                    if you watch the last video I linked, you will see that before running the engine, he "oiled the pistons". Each of the 4 cylinders has a small cup that he put oil in, which presumably went right into the cylinder. I was not clear if the little screw he turned wa a drip oiler or just a valve to let oil in, which is closed before running. I suspect the latter.
                    It would seem to take VERY little leakage to make the engine not run. Presumably his oil, and your WD40, lubed and sealed the piston enough more to make it work.
                    • Great news Brian, Congrats!!
                        Super!
                        What a great post. Now if you'd just figured it out and posted it before Brian figured it out, that would have been great. Could have saved days of angst for Brian.
                        Brian, congrats on another successful build. YOU are amazing!
                        Dan
                        • Brian:
                          I thought you concluded that you WOULD oil the piston? I seem to recall you had started out figuring to run it dry, and I thought you had decided to use oil. If so, maybe the WD diluted it and made it thinner, less "draggy". It wasn't very draggy in the video from before, though.
                          Looking back at the videos, the one you had where it did not work (that I missed seeing):
                          https://www.youtube.com/watch?v=JPiwXM4xSvM
                          In that one, it did not look nearly as "free" as in the other one where you demonstrated how free it was. I'd say it only coasted about 1/3 to 1/2 as long in that link above as when you did the coasting demo.
                          Was there any difference in lube?
                          • As an experiment, put some ice over the cooling fins. I predict the engine will speed up substantially.
                            Is there an icicle handy?
                            Allan Ostling
                            Phoenix, Arizona
                            • I can speed the engine up a bit by relocating the alcohol flame. I'm sure that ice on the cylinder would make it run longer--not real sure about faster. The engine runs for about 20 minutes until the cylinder heats up enough that there isn't much heat differential between the flame and the cylinder temp.--Then it slowly dies and stops.
                              Design engineer
                              • danlb--Thank you. Makes me feel warm and fuzzy all over, knowing that somebody thinks I'm amazing. I'll go to bed tonight with a big smile on my face.---Brian
                                Design engineer
