Brian does Ridders flame eater
  • #31
    Hi,
    Ridder's plans call for drilling that setscrew hole at a 45deg angle in the hub. I didn't see doing that either and did the same as you, and drilled straight through the flywheel. It kind of detracts from the look of the rim a bit, but it's much easier to do. I think maybe I should make a plug to fill the hole.
    • #32
      Guess I should pay more attention, its been on every rendering and blueprint posted.
      Besides following the plans is there a reason not to just make the flywheel and shaft out of just a single piece of material?
      • #33
        VOILA!!! We have a base for our flame eater engine. I was supposed to go across town today to my "real job" but got a last minute reprieve by email. I hope my bearings come in today.
        Design engineer
        Barrie, Ontario, Canada
        • #34
          Brass is heavy, and very pretty, but you really don't want it for a shaft. It doesn't stand up to that type of use particularly well. Also, brass costs a fortune, and you don't want to be buying a great big lump of it to turn into chips to incorporate the shaft into the flywheel.
          Design engineer
          • #35
            In the above picture you can see the chatter marks made by my parting off tool when cutting the fins. Other than a narrow file, does anybody have a better way to get rid of these chatter marks?
            Design engineer
            • #36
              I use a 1.0 strip of emery folded in a "U"..
              If needed, fold it over a backer, like a paint stick for instance.
              Sid
              • #37
                Sid
                This will work, a popsicle stick comes to mind. A small file as you mentioned would also serve well.
                I would be inclined to use a very narrow HSS tool bit ground to simulate a parting tool. I have several like this ground from either a 3/8" or 1/2" blank ground down to about a .030" width that I use for O-ring grooves or fine detail work much like what you are doing.
                My only concern is that being 316ss it may now be work hardened.
                • #38
                  Leave them alone, look pretty and will add to the surface area for heat transfer.
                  • #39
                    I spent the lions share of today making a crankshaft, a crank throw and con-rod big end pin. I called about my bearings but they won't be in until tomorrow. I also drilled the 1/8" hole for the valve rod full length of the cylinder---You can see a 1/8" piece of cold rolled setting in the hole.
                    Design engineer
                    • #40
                      Did you braze the crank disk to the shaft?
                      • #41
                        No--Silver solder
                        Design engineer
                        • #42
                          With the "low power" available from these engines, doesn't running that rod through a hole cause some additional frictional losses?? It's bound to rub a bit isn't it?
                          ...lew...
                          • #43
                            It probably does. Lew, but I just watched a dozen videos of this engine all built by different people on Jan Ridders website, and they all ran with the rod in the same place.---Brian
                            Design engineer
                            • #44
                              No--Silver solder
                              Yikes!
                              • #45
                                Why Yikes? The heat from an alcohol burner isn't going to melt silver solder.
                                Design engineer
