All my life, when I've wanted to join bits of steel together, I've used a stick welder. 99% of what I do is stuff like 2" to 4" box section, angle, strip, that kind of thing. Very rarely stainless, and nothing that's going to be used on the space shuttle etc. I have a 350A Lincoln AC stick welder.
I'm now tempted to go for a used MIG welder. Largely because of the reduced mess from slag.
I had a go with one, and was surprised how easy it was to use. The one I tried was this one: http://www.parweld.co.uk/wp-content/...age.pdf?x71399 300A at 30% duty cycle. First welds that I made looked lovely, much to my surprise.
Really nice machine, but 1400 euros new. I'm looking to pay about half of that, for a used machine. There's lots on the market in that price range, also from known makes - Esab etc.
What should I look for when buying? The owner mentioned the 4 roll drive as being desirable, along with having most things adjustable (soft start etc). What goes wrong with these things?
The machine was set up with 0.8mm wire; will this do for most jobs?
Considering that I'll only be welding mild steel (no stainless / aluminium) with it, what are the "must have's", what can I do without? 3m of hose will be enough; it'll live beside a dedicated welding bench. Maximum metal thickness that I'll need it for will be 10mm, maybe occasionally more, but I'll keep the 350A stick welder for that. I'm looking for a 3 phase machine, as I have a 380V 25A power supply.
I don't think that I'll need a water cooled torch; I don't do huge amounts of welding, and I can afford to let things cool down. Not sure what I'll do about the gas bottle; buy, rent? A cylinder will probably last me 2 years, and I have a supplier around the corner. Equally, getting the welding wire is not an issue. The one I tried was a CO2 / argon mix.
Wise words?
Thanks,
Ian
Wise words?
Thanks,
Ian
