I've been a bit 'enthusiastic' with my vise handle and it's now somewhat banana'd. I've also discovered that haemoglobin isn't an effective lubricant for cheater bars...but that's another story
Anyway, I'm thinking that it'd be fairly easy to thread the ends of a 12mm rod, screw a ball on each end (no torch, so peening not an easy option) and blam, vise handle. All I have in stock is EN1A which is described as "free cutting mild steel" and according to this table equivalent to 1113 or 1213. I figure this will bend much easier than the original handle and hence, not be of much use.
I've seen someone making vise handles out of 1144 steel but I can't get that without shipping it in from the US at a cost higher than buying a new vise. I figure it needs to have high tensile strength so as not to bend but still be machineable enough to put a thread on the end. I'm also thinking that if/when it does fail, it would be preferable if it bent rather than snapped. I know that I can get EN3B, EN8, 16, 19, 24 and 36. Can anyone suggest what I need to be looking for in the selection and why please? (The why is so I have more of a clue going forward)
Many thanks,
Gareth
Many thanks,
Gareth
