A pot into a guard
  • A pot into a guard
    Just thought I would throw this out there for anyone that needs to make a guard fairly easily.
    So I needed a guard for my grinder, I thought about it off and on for a week, trying to think about what I should use to make the guard... then it hit me, I went to a second hand store looking for a suitable pot.... and found a pressure cooker that was the right size... and probably 3/16" thick.
    I measured it and drilled a hole and cut it with a jig saw.
    Popped out the rivets for the handle and welded a piece of round stock to a small plate to bolt the handle on.
    Quick and easy.
    I like........
      What a Super Idea!!! You win the prize for best idea of the day, It's worth $$$$$ :-)
        Excellent, thanks for posting
          clever - well done!
            Very nice. Thanks. JR
              brilliant.
                Nice!
                I sure hope you had permission to abscond with the wife's favorite pot.
                  Originally posted by CCWKen View Post
                  Nice!
                  What pot?
                    It looks like the new guard is larger than the old one. Are you using a larger wheel than the machine is designed for? If so is the new wheel rated for the rpm's that you will be running? Broken grinding wheels are usually not a pretty sight.
                      Looks like it's a 7" wheel on a direct drive (3600rpm) grinder. So probably a better match for speed than the original wheel!
                        Originally posted by Mcgyver View Post
                        clever - well done!
                        +1. Neat, dead neat.
                          I like that fact that you repurposed an old pot and used your machines to make something useful.
                          You should a GOLD STAR for that!
                          Jack
                          I'm Happy because I am retired
                            Great job! Looks nice and stout.
                              Brilliant idea and nice job.
                              I often wander around stores looking for things that I can re-purpose. In fact, I was doing that last evening at Lowes. I wound up with a 4x4 electrical box and a couple of 1.5" PVC pipe fittings - for the same project.
                              Make it fit.
