Originally posted by Toolguy
View Post
That's a tough one. I have both. My knee mill does have a Kwik (not a misspelling) change (sorta) tooling system. It does only have 6 inches of quill travel, and at first I kind of begrudged the effort to crank up and down the table, but in some ways its easier when it comes to setup. I just crank the table up until my tool setter reads zero, remove the setter, and press start. I always leave the home z offset set at the height of the tool setter. I never fiddle with it or accidentally crash into the tool setter. One might argue that I should also tighten up the knee every time which would make it more tedious, but I've never had any issue with it so I just leave knee locks loose and go. If I used the tool tables it would not work out to be so convenient. Tool lengths would be an issue when say changing from a stubby mill in a screw lock tool holder to a half inch jobber drill in a drill chuck. Just like you say. I actually tried to use and setup tool tables on the machine at one time, and if I used it for a specific range set of jobs it might be possible. Since its really a more general purpose machine that didn't work out. Of course for me the big deal about the mill was the price for a heavy weight (middle weight by today's standards.) I bought it at auction for $500 and put about 2 grand into retrofitting it to a modern control system. Do I wish I had a bed mill the same weight and the same power? Sure I do, but this machine is very utilitarian for me too.
The advantage to a bed mill seems obvious, but its about size - and quality. On my little high speed machines I only have about 6 inches above the vise. Of course they would never drive a 1/2" jobber drill LOL. If I need a 1/2 hole I do it with spiral interpolation and a 3/8 or 1/4 end mill. I have crashed the tool into a tool setter before and damaged the setter or broken the tool. A couple of them over the years. I had a bigger bed mill at one time, but head nod and quality played a huge part in why its no longer in service in my shop. Gack!
If all things were equal I might prefer a bed mill over a knee mill, but all things are almost never equal.
Originally posted by MaxHeadRoom
View Post
P.S. I have considered putting a power feed on the knee of my KMB1, but I've gotten used to it now.
