Originally posted by Doc Nickel
View Post
If not a Tormach 1100, then what?
Originally posted by Sparky_NY View PostYou don't show a location but used VMC's do turn up very reasonable. I seen 3 Fadal VMC15's here in the last year, $5000 ea, under power and producting.
Problem with used industrial machines is they were sold for a reason. Time cycle was up, and properly so. Bearings on those machines?!?!? Big bucks.
And yes, I have three lathes and three mills. Only one is new to me. And all pretty old.
I think you came here to bounce your main pick off of us to see what gives.
The Tormach has been known to be a working machine. And there is tech support. Win win I say.
What will be you fist project? Mine is usually getting the new mill workingJR
Originally posted by JRouche View PostFor sure, it has been running 24/7 for 8-12 years. Thats why five grand. Some haas machines can be found (not Fadel quality) for 10k and up.
Same as you, getting it setup and going.
Current projects are:
1) Finish lathe DRO install
2) Convert 8x14 lathe to CNC(ordered a 2025 ballscrew for Z, 1204 for X)
3) Machine the waterjet cut frames for my 4-6-2 steam loco project
Sent from my iPhone using Tapatalk Pro
Originally posted by RB211 View PostThat settles it, Tormach it is!!! My entire house is 150 amp service.
Originally posted by lakeside53 View PostNooooo... you can't stop thread after only 15 posts Someone has yet to suggest a diesel generator in the yard to run the pig VMC, then the usual suspects will tell you all the code issues and reasons why you can't.
Originally posted by softtail View PostWhat are you going to making with the Tormach.. anything specific? I ask from curiosity and jealousy.
Originally posted by JRouche View PostMy industrial hobbies machine is servo closed loop. It is now called charter oak but I am not sure of their quality. JR
http://charteroakautomation.com/Mike Henry near Chicago
Originally posted by Sparky_NY View PostYou don't show a location but used VMC's do turn up very reasonable. I seen 3 Fadal VMC15's here in the last year, $5000 ea, under power and producting. The seller bought all new machines and needed the room. Be advised, even small VMC's weight north of 10K lbs and need 50-100 amps of power. You would not be unhappy with the tormach, they have a excellent reputation.
Haas TM-1 25A full load/3 phase or 40A/single phase
The TM1 is what is commonly known as the "mini mill". Its a great machine but over 3 times the OP's budget. Used ones command VERY high prices. The odds of finding a decent Haas anywhere close to the OP's budget are highly unlikely.
Threre are small VMC's out there fairly cheap BUT they are in BIG demand by hobby users and rare to find. The leadwell MCV0 is good example. There was one locally 3-4 years ago for $5K
