Have a Toyo ML-1 lathe which takes 20 x 42 x 12mm bearings. Got single row Angular Contact to fit. Now for the silly question. Which way do I install them on the spindle?
Angular Contact Bearing Installation?
Originally posted by NiftyNev View PostHave a Toyo ML-1 lathe which takes 20 x 42 x 12mm bearings. Got single row Angular Contact to fit. Now for the silly question. Which way do I install them on the spindle?
https://www.gmnbt.com/spindle-bearin...nical-info.htm
Not familiar with the ML-1 specifics so for better quesses you need to specify how many bearings, if there is spacers and where the preloading nuts are located.Location: Helsinki, Finland, Europe
Two bearings, no spacers and just nut on tail of spindle IIRC. Had it apart for years and just getting around on putting it back together. Can't rush these things. LOL. Just need to remember where all the bits belong.
Link to Toyo - http://www.lathes.co.uk/toyo/page3.htmlNev.
Originally posted by NiftyNev View PostTwo bearings, no spacers and just nut on tail of spindle IIRC. Had it apart for years and just getting around on putting it back together. Can't rush these things. LOL. Just need to remember where all the bits belong.
Link to Toyo - http://www.lathes.co.uk/toyo/page3.htmlLocation: Helsinki, Finland, Europe
You want the front bearing (nearest chuck) to be the thrust bearing .
Look at this bearing cross-section
http://www.skf.com/us/products/beari...ngs/index.html
The right side on this bearing should be close to the chuck, so this picture fits your installation perfectly for the front bearing.
The rear bearing will be opposite , so your draw nut on the ( spindle )assembly will tighten both bearings and give you the most rigidity
RichGreen Bay, WI
Also meant to comment on bearing design. A 25 to 40 degree pressure angle on a angular bearing usually has a large shoulder on one side of the inner race, and a large shoulder on the opposite side for the outer race. You can easily see this in the SKF link I posted.
Lesser angle bearings may only have the outer race with a larger shoulder...see the photo of this in the Link for post # 2
In either case, you always want the outer race large shoulders to face the inside of the headstock.
RichGreen Bay, WI
Originally posted by Rich Carlstedt View PostYou want the front bearing (nearest chuck) to be the thrust bearing .
RichNev.
If this is a typical 2 bearing machine, will not one be at the nose, and the other at the tail end of the spindle, with the preload set by the tail nut? No spacers or special grind used then. We have not been granted a picture of the setup, the link does not seem to show it, but the OP said no spacers etc.
The bearings would both be set up to take thrust "inward" into the housing, so that when the nut is snugged to set preload, the bearings support the tension in the spindle.4357 2773 5647 3671 3645 0087 1276
"There's no pleasing these serpents"......Lewis Carroll
Originally posted by J Tiers View PostIf this is a typical 2 bearing machine, will not one be at the nose, and the other at the tail end of the spindle, with the preload set by the tail nut? No spacers or special grind used then. We have not been granted a picture of the setup, the link does not seem to show it, but the OP said no spacers etc.
The bearings would both be set up to take thrust "inward" into the housing, so that when the nut is snugged to set preload, the bearings support the tension in the spindle.Location: Helsinki, Finland, Europe
