Senft "Poppin" ENGINE
  • #61
    I never said I didn't like it. It's just very strange, that's all. It's uglier than original sin right now because it looks weird and isn't finished. By the time I'm done with it Sid, it'll be just as pretty as I am----
    Given that, better go for the redesign........
    • #62
      The con rod big end does look okay now that it is finished and fitted. I have never made one this way before, so it was a new experience. If you really, really need radial clearance around the crankshaft, then this is probably a good idea. I don't particularly care for this method, as your options are very limited for any kind of adjustment. At any rate, it seems to work, and I've managed to do something "just a little different".
      Design engineer
      Barrie, Ontario, Canada
      • #63
        I used one of my new laps to lap the bore of the cylinder. I only used a single stage of lapping using 600 grit paste. This isn't perfect, but it's good enough for what it will be doing. To be perfect, I would have used grit in three successive stages, using #300 first, then stepped up to 400, then up to 600. There's a little story that goes with this. When I first started machining eight years ago, I bought a number of new, expensive reamers. They would ream a bore and leave it almost flawless inside. Over the years, the reamers have grown more and more dull, not leaving a perfect finish anymore, but that was okay--My 3 stone brake cylinder hone would clean up any imperfections prior to lapping. But--On a cylinder with a 5/8" bore, the hone will not fit into it. The finish after reaming did have scratches and flaws in it, and I had no good way to clean the bore up. I have been contemplating buying a set of expanding laps for a few years now, and this seemed to be the time. I will still probably shop for a smaller diameter hone, but for now the lap has cleaned things up sufficiently. Another factor in all of this is that on all of my i.c. engines, I have been using Viton rings, which are very forgiving of surface finish. If the surface finish isn't perfect, it will be after running for an hour.--The Viton rings will polish the inside of a cast iron cylinder to a mirror finish in about an hours running.-You might have to replace the ring after that first hours running, but Viton rings are cheap.
        Design engineer
        • #64
          I bought a new #2-56 die today to thread the ends of the cross shaft that operates the valve. I have no idea what happened, but after threading down to the shoulder of the shaft and then backing off (by hand), the diameter of the shaft was decreased but no threads were on it. Very puzzling. Then I ran a #2-56 bolt thru the die, and it matched the threads just fine. Then I ran a #2-56 nut down the same bolt and it threaded okay. I had the shaft ends turned to .085". A mystery, and now I have to make a new shaft.
          Design engineer
          • #65
            Mystery solved! "Gremlins" I have them in my shop too. Been seeing them around since about the time I turned 65.
            Bert
            • #66
              Not sure if you can find them down to 5/8" but I have a set of brake hones made for honing caliper bores. They are pretty small, I think my smallest can do a 1.25" hole. Might be worth a search if you're interested.
              • #67
                This morning I have decided to put on my design engineers hat. Mr. Senft did a marvelous job on this engine, But---there are a couple of spots that I see as potential problems. The 1/8" diameter cross shaft which operates the valve was originally designed as having the ends turned down to .085" and threaded #2-56 and the flat arm with the roller on it was sandwiched between the nut and the shoulder on the shaft. There was no key of any kind to make that arm hold it's position, and as expected, it slips. I have been warned of this by my own experience on similar mechanisms and by Nick, a gentleman who has successfully built and ran one of these engines. Yesterday when I tried threading the ends of the rod I had made with a new #2-56 die I had just purchased, it screwed up the end of the shaft and didn't leave any thread??? So--this morning, a redesign. The cross shaft now has plain ends with no turn down. The plate "arm" how has a hub with two #5-40 set screws holding it in position on the shaft. The far end of the shaft which originally held a spring clamped between two hex nuts will receive a similar treatment with a hub and set-screws holding the spring.
                Design engineer
                • #68
                  I like that valve arm a lot better now. I added a hub with two set screws to the arm and made a separate hub for the end where the spring goes. I have also finished the brass part that bolts to the graphite piston. In fact, the only thing i have left to do is make the graphite piston and then reassemble everything.
                  Design engineer
                  • #69
                    I haven't had time to stop and sort out the die, but I will get to it eventually. I finished the graphite piston, and got a good "sizing" on it. The last couple of thou. were taken off using the back side of my 280 grit sanding strips.
                    Design engineer
                    • #70
                      I was mistooken---Got everything back together and then realized I still had to make the valve rod and the valve itself. The engine turns very freely through half of it's rotation, and has a bind in the other half. Tomorrow I hope to get the "bind" sorted out and make the last two pieces.
                      Design engineer
                      • #71
                        So here we are at the almost last stage. Loosening the engine up to absolute minimum friction. If an engine has a slight bind on part of the full 360 degrees of rotation, before I start tearing things down I try this. About 80% of the time, it works. I like to let he engine run for an hour or hour and a half. at around 400 rpm. if the bind isn't gone in an hour and a half of running, then something mechanical is out of whack, and the engine will have to be torn down and "sorted".
                        Design engineer
                        • #72
                          This morning I've been experimenting with my new dies. I have a #0-80 die for threading 1/16" diameter stock and a #2-56 for threading 0.085" stock. On first try, neither die would take hold and start cutting threads. I then forced them to start with lots of pressure, and they threaded about 3/8" of stock before I backed them out. They did an amazing job of cutting the 1/16" and 0.085" stock down to a smaller size, but left no thread. I then tried putting a slight taper on the end of the stock, and tried again.---Same results!!! I've never had a problem threading stock before, but I've never threaded anything this small. Next step was to use the tiny little screw in the die to open the die up a little. This did work, and I have achieved some pretty respectable threads in 1/16" stock.--Of course I don't have any nuts to try on my newly created 0-80 threads--they are supposed to arrive here tomorrow. The 0.085" diameter for the #2-56 thread is not a size I stock, but I will turn some stock and try it again with the die opened a little. (I do have #2-56 nuts on hand to verify if this will work for the #2-56 threads.)
                          Design engineer
                          • #73
                            Brian - you don't say what you are holding the dies with. I made a die holder to fit in the tail stock of the lathe and find it works very well. Seems like you need a bit of constant pressure to get those little guys started, specially in harder metal. I keep the tail stock pressure on until I get at least a few threads started. The tail stock die holder also makes sure the die is square with the rod you are threading. Yes, sometimes I have to open up the die for the first cut, then if the thread is too tight I close it up a bit and make another pass until I like the fit of the thread.
                            Larry - west coast of Canada
                            • #74
                              The last time I saw nuts this size they were on a Bumblebee!!!
                              Design engineer
                              • #75
                                I'm not exactly forging ahead, but I am making progress. The engine has loosened up nicely after an hours running. I think I've figured my dies out now, at least I have them cutting threads that the store bought nuts will fit onto. I have a temporary base bolted to the engine at the moment, as there is no way to hold the engine down without an auxiliary base. I have to figure the spring out next that holds the valve open (the cam closes it.)
                                Design engineer
