Another RANT
Originally posted by mklotz View PostThis from someone who lives in a country where they use stones to measure weight and a "hundredweight" weighs 112 pounds.Location- Rugby, Warwickshire. UK
Originally posted by Mark Rand View PostStones don't wear much compared with plastic, and 112lb cwts allow for a quantity discount. At least we don't use short tons to weigh things, let alone the anorexic pints of beer!
If you had, you'd be grateful that you only had to drink a short pint of it.CNC machines only go through the motions
Originally posted by Mark Rand View PostNow you're just bragging Russ.
So I was genuinely curious, and for the most part I think it is still good advice. The bit that surprised me was that the screw machine drills held size so closely, and that the carbide drill was oversize as much as it was. I think I should get a new #31 in both screw machine and jobber sizes and see where they land, single samples like this aren't very good data sets.
But anyway, poking a hole with a drill has no guarantee that the hole will be on size, about all you can say is that the holes won't be smaller than the drill.
Drilled holes are not that exact anyway. If you want an accurate sized hole you are going to have to use a reamer. Reamers are available by thousandths and even smaller increments for certain sizes. Just drill is a bit small and ream to size.
BTW, if you really want a drill of an exact size, you could grind it down. Spin the drill bit and run it across the wheel. The OD of a drill bit, the margin area, is cylindrical anyway.Paul A.
Perhaps you can grind a slight taper on the drill, so you can adjust the size of the hole by how deep you drill. The thread-forming screws are tapered as well. I found some tapered drills, that match the taper of screws, but are made for woodworking:
http://www.rockler.com/rockler-insty...red-drill-bits
Or a tapered reamer:
https://www.travers.com/high-speed-s...elistname=SITE
There are many sizes of standard taper pins:
https://www.smithy.com/machining-ref...turning/page/7
Reamers for taper pins:
http://www.atlascuttingtools.com/cat...traight-Flute/http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
