Last fall I had a friend put a new motor in my aunts a furnace, the original kept setting up, it's only 1/4" HP and the bearings were gone.
He found a cheap replacement. As soon as he fired it up it hummed quite loudly and the sheet metal enclosure amplified the humming.
So..... we took the motor out and bench tested it. You could feel it buzz when it was running on the bench. So we put it back in. It's running OK, and has been for a few months but it's noisy. If you kill the power the buzzing stops instantly. It's not an out of balance issue. Only buzzes when power is applied. Any idea what causes this??
The old motor ran dead quiet, all you could hear was the air blowing through the ducts.
JL.................
JL.................
