Hi all. I'm starting to get serious about the setup and troubleshooting of my 1983 Enco 12" belt drive lathe I purchased a few years ago. I recently pulled the spindle and jackshaft to change to an appropriate belt length to allow me to use speeds over 500rpm. Doing so resulted in a clearly evident lack of power from the PO supplied 3/4HP cap start only motor. I recently fitted a 2HP 3 phase motor and VFD, which was a nice project and a good success, but I've discovered my capability not really increased as I'm getting very quick and noticeable chatter/vibration on parting with a 2mm wide insert tool or taking a turning DOC of 0.050" off the radius or more. At slower speeds with HSS previously I've had pretty good luck taking 0.050" off the radius and even 0.100" on good material.
I don't yet want to turn this into a thread looking for suggestions as I've read a ton on this topic and have only started taking actions down the correct path. The supplied stand is not bolted to the floor and as such I can't do a proper "leveling"/de-twisting as the lathe is not heavy enough. My next step is to bolt the stand down, fill it with sand or concrete, and properly setup the lathe. I'm expecting a pretty massive improvement with that effort.
I'm just looking for a sanity check at this point about what I should expect from this lathe. It seems to me I should be able to run the described cuts even with carbide insert tools (CNMG and CCMT). Can anyone with a similar lathe comment? And maybe include the details on your stand.
