The task is some 1/2-20 threads in some Stainless of unknown heritage. I know it was a propeller shaft from a 5 litre hydroplane. I also know it is magnetic.
So I drilled a 29/64 hole 1.25 deep in a couple of pieces and proceeded to tap with a brand new quality tap. As they are blind holes it was tap a bit then remove and clean the tap and the hole.
Part way down there were some problems with the quality of threads.then it seemed to get better. Obviously it did repair itself but it cut with ease.
So here are the questions/thoughts. 1) Does some Stainless have hard spots possibly caused by getting hot and if so what rough temperature might it take? 2) I made some soft jaws for my vise that are 1/2 inch Baltic Birch plywood held on with "Super Magnets". Would it be conceivable that the magnets were affecting the clearing of chips?
Your thoughts and questions.
Thanks in advance
Pete
Thanks in advance
Pete
